Posted February 3, 2011 SCHUMACHER, main sponsor of Petitrc Race since 2006, sent to PETITRC their pics of the Schumacher CAT SXIII! SCHUMACHER, partenaire de la Petitrc Race depuis 2006, vient de faire parvenir à PETITRC des images de leur nouvelle monture le Schumacher CAT SXIII Schumacher CAT SX3 1/10th Competition 4WD The new CAT SX3 follows on from the highly successful CAT SX range. Stronger and more durable than ever before! An all new mid-motor design with central lipo battery positioning offers fantastic balance, control and agility. Jumping like the Pro's is made super easy with the new compact layout and corresponding motor/wheel rotation. Awesome acceleration and straight line speeds are still achieved. With the inclusion of the excellent large capacity big bore shocks, high down force MAX sized rear wing and new cool body the CAT SX3 remains the market leader. Designed to race, designed to win! The CAT SX3. <img src="http://www.petitrc.com/gallery/files/3-catsx3_ftq_body_side_1000.jpg Features; -NEW Mid motor layout. -NEW Optimum weight distribution with saddle pack lipo layout -NEW 3 belt transmission with efficient low tension belts running on large size CNC machined pulleys. -NEW Precision, hardened steel transfer gears. Superb durability. -NEW Rubber sealed, super precision ball bearings throughout. -NEW Larger layshaft bearings. -NEW Rear belt power roller and mid belt tensioner now included. -NEW Adjustable internal transmission ratio (2.2:1, 2.6:1, or 3.0:1) to optimise ratio for all motors. -NEW design tight fitting body and undertray. Offers excellent dirt protection, aerodynamics and cooling options. -NEW easy to assemble, rigid wing mount system. -Motor rotates the same direction as the wheels creating a car with superb jumping responsiveness and no torque steer effect as is common with shaft drive cars. -Super free ball diffs with silicone nitride balls, pro spec thrust bearing, and lightened steel outputs. -Strong steel universal joint driveshafts. -Smooth twin pad slipper clutch with easy access adjustment. -Unique clamp motor mount to fine tune weight distribution, and allow motor changes without affecting gear mesh. -Industry standard wheel fittings. -Eccentric bearing housings for adjustment of belt tension and diff height. -Layshaft or front one way option. Overdrive front pulley option. -2.5mm aerospace grade carbon fibre chassis and top decks. -Horizontally split transmission housings for ease of maintenance and diff access. -Ultra narrow chassis design to minimise grounding on roll. -Rigid servo mount directly onto transmission housing for precise steering. -Max sized rear wing. -Class leading suspension geometry with durable components and a huge range of optional alloy parts, offering adjustments to set up your CAT SX3 to any track conditions. -Adjustable rear roll centres, inboard toe-in/toe-out, anti squat and track width (using optional Speed Secret parts). -Adjustable front roll centres, inboard toe-in/toe-out, track width and rake angle (using optional Speed Secret parts). -Pro spec big bore shocks with titanium nitride shafts, CNC machined pistons with recessed ‘e’clips, threaded collars, twin O ring sealing and diaphragm volume compensation. -Strong and rigid 4mm carbon fibre shock brackets. CAT SX3 S1 version includes; -S1 Composite Material replaces all Carbon Fibre components. -All further spec's the same as Pro C/F Version. Gallery Share this post Link to post Share on other sites
Posted February 3, 2011 C'est beau! Et miracle, ils abandonnent (enfin) les elastiques du support aileron! Share this post Link to post Share on other sites
Posted February 3, 2011 ouais mais ça me saoule il va encore falloir de la place sur mon étagère Share this post Link to post Share on other sites
Posted February 3, 2011 Oh une transmission de XX4. Comme quoi, ils étaient vraiment en avance sur leurs temps chez losi. Share this post Link to post Share on other sites
Posted February 3, 2011 c'est clair,mais pour moi c'est exactement la même que mon cat sx,juste qu'il ont mis le moteur central,toujours trois courroies Share this post Link to post Share on other sites
Posted February 3, 2011 Suis pas Purple du tout ! :grin: Mais j'aime bien cette version. Share this post Link to post Share on other sites
Posted February 4, 2011 Il fallait s'y attendre... Ils nous avaient déjà fait le coup avec le Cat 2000 et le Cat 3000. Reste que ça t'oblige aussi a passé a des accus saddle. Et du coup, ça fait un gros changement (et investissement) pour celui qui voudrait changer son Cat SX ou SX2 pour un Cat SX3. Mais si non, c'est vraiment beau et bien fait. Share this post Link to post Share on other sites
Posted February 4, 2011 Oh une transmission de XX4. Comme quoi, ils étaient vraiment en avance sur leurs temps chez losi. ? Pas grand rapport... par contre je suis d'accord avec toi, pour ce qui est du moteur à l'AV ils avaient vu très juste... De nos jours ça semble indispensable en TT. Share this post Link to post Share on other sites
Posted February 4, 2011 en regardant les photos de ce nouveau châssis, il pourrai nous sortir un kit de conversion du cat sx2 en sx3! d'apres ce que je peux voir des photos il faudrait un châssis, les platines, support de packs, support de "boite de transmissions", support moteur! Share this post Link to post Share on other sites
Posted February 4, 2011 en regardant les photos de ce nouveau châssis, il pourrai nous sortir un kit de conversion du cat sx2 en sx3! d'apres ce que je peux voir des photos il faudrait un châssis, les platines, support de packs, support de "boite de transmissions", support moteur! et une nouvelle carro beaucoup plus flatteuse Share this post Link to post Share on other sites
Posted February 4, 2011 Une question importante... Ce SX3 il sera disponible quand ?? (a moins qu'il le soit déjà) :=B: Share this post Link to post Share on other sites
Posted February 4, 2011 donc debut été ? il me plait ce chat:buggyred: Share this post Link to post Share on other sites
Posted February 22, 2011 Schumacher’s new CAT SX3 has taken the top 3 Qualifying positions at the very popular Schumacher Indoor Masters at Worksop over the weekend. Prototype versions of the new car were in action for the first time in public competition and dominated qualifying. Simon Moss won all 4 qualifying rounds ahead of a competitive field showing huge potential and already showing great speed. Not only did Simon TQ but this was also followed up by Grant Williams and Tom Cockerill qualifying 2nd and 3rd respectively with their new cars. Unfortunately work commitments meant that Simon had to head off before the finals. TQ Simon Moss - CAT SX3 2 Grant Williams - CAT SX3 3 Tom Cockerill - CAT SX3 4 Nathan Waters 5 Paul Bradby 6 Craig Collinson 7 David Poulter - CAT SX2 8 Rob Fox 9 Greg Williams - CAT SX2 10 Adam Skelding This left Grant and Tom to try and battle it out in the single leg final and after some good fighting Grant got the better of Tom. A perfect weekend for the car was almost wrapped up only for an unfortunate incident with a corner marshal prevented Grant from winning. In the end Grant came 3rd behind Nathan Waters and Craig Collinson. All in all a good showing for the new car. schumacher Share this post Link to post Share on other sites
Posted February 23, 2011 et puis bientôt l'axis3 en touring? Share this post Link to post Share on other sites
Posted February 23, 2011 Oh je suis décu... ils auraient pu faire un effort et essayer de mettre 5 courroies... 3 je trouve ca pas assez LOL Share this post Link to post Share on other sites
Posted April 19, 2011 Simon Moss - Schumacher CAT SX3 Simon Moss and 6 other Schumacher drivers were piloting the new CAT SX3 buggy in 4WD - an evolution of the original SX design with a central motor location and revised drivetrain. The new car isn't available yet but is already showing its pace in testing and here at the opening National with Simon Moss qualifying 3rd. It uses a similar feature set from the older generation cars - 3 belts and 'reverse motor' which runs the same direction as the wheels. The new motor location should help balance the car and put the power down. The original SX layout was really designed for NiMh cells with a 4-2 split but was born at the dawn of Lipo acceptance. With the new car being fully developed with help from team drivers and Tom Cockerill's summer work placement - the new layout is sure to be a huge hit. Like a few other Schumacher drivers - Simon was using Team Durango driveshaft boots to protect his differentials from dirt ingress. We believe he might have been testing a lightweight differential option under those covers. oople Share this post Link to post Share on other sites
Posted April 20, 2011 http://www.petitrc.com/_forumphp/showthread.php?t=57731 Share this post Link to post Share on other sites
Posted May 3, 2011 Le retour du TDS !!! Il me semble qu'un Français avait fait le même montage en reprenant une partie des pièces d'un TDS de Cat 2000. Si Schum commercialise un TDS pour le CAT SX, je pourrai peut-être le greffer sur mon antiquité... Share this post Link to post Share on other sites
Posted May 3, 2011 Il me semble que le tds était déjà disponible pour le cat sx 2. Sous appellation fab (front adjustable breaking). Share this post Link to post Share on other sites
Posted May 16, 2011 Trish Neal's CAT SX Trish Neal has a knack for engineering cool innovations and finally has his hands on a pre-production Schumacher CAT SX3 - and already is making parts for the car! Trish has created a central brass weight whih sits just under the rear drive belt - following its angle. The brass is to give some more weight where the cells sit for balance but unlike one of the brass lipo trays that are commonplace - this keeps the weight in the centre where it's best. Trish also created a quick-release for the front pulley - machining the alloy bulkhead and bolting on a carbon plate to hold down the pulley and allow it to be pulled out quickly with needing disassembly. oople Share this post Link to post Share on other sites
