Posted June 3, 2009 Après avoir reçues les photos hier mises ci dessus par Reporter, comme convenu, voici les toutes dernières nouvelles envoyées à PETIT RC par Team Durango ce jour. Cela répondra ainsi à vos questions lues ci dessus : Team Durango is proud to reveal official WEBSITE, SPEC and PRICE of their eagerly awaited DEX410 – 4WD Electric off road 1/10 scale competition buggy. Designed and engineered in Germany, the DEX410 has been in development for several years, with the prototypes being raced by famous Champions like Craig Drescher, Atsushi Hara, Hupo Hönigl, Mark Pavidis, Marc Reinhard and many more. The production version of this prototype car - that has five times made the World’s top ten & seven times the Euro’s top ten - will soon be ready for public release! Estimated public launch end of June’09 Team Durango is “serious about racing” so the cars are defined by their engineering precision, attention to race-winning detail, innovative design and ground-breaking features. Features NEW to this racing class – FASTER ON THE TRACK & less time in the pits For best handling - • Super stiff and ultra narrow aluminium chassis with unique transmission give perfect weight distribution and low centre of gravity Maximum power - • Metal gear differentials for zero slip and tuning options from the diff oil Minimal maintenance & wear- • Shock-absorber & drive shaft protective drive-boots • Sealed gear differentials Fast even in the pits • Quick-release battery mounts (Sub-C / LiPo), slipper-clutch and spur-gear • Incredibly quick diff access (only 6 screws to remove diff & centre UJ) • Quick release mini radio tray for ESC & RX No compromise materials spec on the DEX410 – best DURABILITY Hard anodised ultimate aluminium (7075 aircraft alloy) used for - • Chassis plate • Front steering uprights • Steering plate • Chassis side braces • Suspension holder • Shock bodies • Slipper holder • Motor plate • Shims and spacers Titanium used for - • Titanium turn buckles Top quality steel for – • Steel ring and bevel gears • Steel diff gears • Spring steel drive shafts and UJs • Spring steel axles and diff outputs • Stainless steel hinge pins • Steel HEX hardware throughout Carbon fibre – • 4mm top quality woven carbon fibre shock towers (front & rear) • 4mm top quality woven carbon fibre rear chassis brace Best of the rest - • High impact grade plastics with optimised fibre content, flex and durability for each moulded part of the car • Durable polycarbonate bodyshell and wing • Rubber sealed ball bearings throughout Included – The DEX410 is for top racers, so it is only available as a self-assembly kit, with wheels, clear bodyshell and wing; but without tyres or electrics. Pricing – The DEX410 was conceived pre-“credit-crunch” and is a no-compromise specification with a huge number of new features for the class; this is reflected in the price. Team Durango considered not launching this ultimate spec car and launching a dumbed-down version instead, (more in line with the cars already available). However racer interest has been so high, and running costs seem to be much lower than current cars out there, that Team Durango is going for it, with the ultimate spec as the launch car. Due to the “credit crunch” the DEX410R will follow with its launch around September, with a much more normal specification and perhaps even the class standard ball differentials. Expect the DEX410R to have a street price of around $390 (€306, £270). While the ultimate launch spec DEX410 will be around $650 in the shops. That’s around €510 or £450 in Europe when sales taxes are added.) The DEX410 is available from : Europe Available direct from - Team Durango Ltd (UK) Email: sales@team-durango.com Other distributors and RC racing shops wanted Japan Available direct from Tresrey Co. Ltd and from selected retailers TRESREY Co. Ltd. Tel : +81-(0)53-543-9162 Fax : +81-(0)53-543-9163 Email: support@tresrey.com USA & Canada Available direct from - Team Durango Ltd UK Email: sales@team-durango.com Other distributors and RC racing shops wanted Worldwide note to potential distributors If you live and breathe RC racing, and you would like the opportunity to distribute Team Durango products via your own Team Durango franchise, simply write to: sales@team-durango.com and we will contact you to discuss your interest further Notes to Editors 1. Team Durango Ltd is a registered company in the UK (06887391) 2. If you need more information, please contact Team Durango on: sales@team-durango.com or visit our website at: www.team-durango.com Share this post Link to post Share on other sites
Posted June 3, 2009 ce qu'il faut retenir: il y a 2 versions, le DEX10 et le DEX10R, le R est une version économique (en voyant les prix, tout le monde aura compris cela) dans les caractéristiques: chassis étroit diff à pignon ajustable avec des huiles des systèmes de démontage rapide des accus, slipper et courrone un accès rapide au diff (voir images plus haut) une mini platine pour vario et recepteur les petits soufflets de protection dans le but de reduire l'entretien (ou de prolonger la durée de vie de certaine pièces) dans les matériaux utilisés: alu 7075 (alu d'aéronautique) titane acier pour les pièces de transmission carbone plastique pour les pièces moulées l'auto est monté avec des roulements étanche avec flasque caoutchouc le DEX10 est prévu pour fin juin le DEX10 est prévu pour septembre, avec des matériaux un peu plus classique et peut être des différentiels à billes voila donc rapidement Share this post Link to post Share on other sites
Posted June 4, 2009 Je vais commencer à mettre un peu de tune à droite.:cool: Share this post Link to post Share on other sites
Posted June 4, 2009 et les particuliers peuvent commander directement chez durango ? Share this post Link to post Share on other sites
Posted June 4, 2009 qu'est-ce que c'est bo.... et pas si cher vu le morceau, en fait. par contre z'ont oublie l'etape "demontage des amortos dans leur serie de tofs "changement du diff avant" je pense... a mon avis les cardans tapent dans les tiges d'amortos sinon. Pas grave. Je suis deja amoureux de toute facon. Paul Share this post Link to post Share on other sites
Posted June 5, 2009 et les particuliers peuvent commander directement chez durango ? Tu leurs écrit en anglais, et ils te répondent rapidement... C'est ce que j'ai fais aujourd'hui. Ils m'ont confirmé le prix de 510 euro pour le DEX41O (plus les frais d'expédition a prévoir). :fou: Share this post Link to post Share on other sites
Posted June 13, 2009 Pas mal ce Durango, je me souviens d'un vendeur qui me disait cette marque ne marchera jamais. Je suis persuadé du contraire, et du changement, ça ne fait pas de mal. Pourvu qu'on suive en France. Et que d'autres marques emboîtent le pas, tel ANSMANN par ex.... Share this post Link to post Share on other sites
Posted June 19, 2009 Et on disait qu'il n'y avait pas de place sur le mid08... Share this post Link to post Share on other sites
Posted June 19, 2009 le type a dû passer autant de temps sur l'install radio que sur le montage proprement dit !!! magnifique buggy de luXe , jeunes fanatiques !:carre: Share this post Link to post Share on other sites
Posted June 24, 2009 Réponse aujourd'hui même de Durango par e-mail... L'arrivée du DEX410 est repoussé a la fin Juillet. (il était attendu pour la fin Juin normalement) Il nous faudra patienter encore un peut pour en voir rouler chez nous... :euh: Share this post Link to post Share on other sites
Posted June 24, 2009 il y a plein de piece franchement ont dirait que ça sort de chez Xray cardans traté et gravé, piece anodisé (orange comme la t2 009) piece anodisé champagne (comme les vielle t1FK04) les plastique resemble aissi beaucoup a du xray même le carbonne à la même tronche , c'est cool si c'est soutraité chez HUDY c'est un gage de qualité !! Share this post Link to post Share on other sites
Posted June 25, 2009 Ce buggy est magnifique l'installe radio est amusante mais ou est le récepteur radio ?? c'est filoguidé ?? Share this post Link to post Share on other sites
Posted June 25, 2009 Ce buggy est magnifique l'installe radio est amusante mais ou est le récepteur radio ?? c'est filoguidé ?? Ba à coté du vario :class: Share this post Link to post Share on other sites
Posted June 30, 2009 Voici un lien trouver sur oople qui pourrait en interresser quelques un. Malheureusement c'est en chinois... http://bbs.rcfans.com/viewthread.php...age%3D1&page=1 Share this post Link to post Share on other sites
Posted June 30, 2009 Voici ce dont je viens de recevoir il y a quelques minutes : Due to some modifications on parts materials and design to make competition model more reliable, release date of Team Durango DEX410 buggy has been changed to late July. Recently Team durango development team and Test teams around countries are in a rush to do the final test of mass-produced model with its racing speed. We are deeply sorry for customers and distributors who had already booked the product. Share this post Link to post Share on other sites
Posted June 30, 2009 Source de Joho sur rcfans - Made in China - Share this post Link to post Share on other sites
Posted July 1, 2009 Bonjour a tous !! Chris de la Suisse nouveau sur forum ! Petite question ! Ces fameux diff a pignons dans bain d'huile qu'en pensez vous ???? car la je dois dir que je suis sceptique!!! Share this post Link to post Share on other sites
Posted July 1, 2009 salut pour avoir vu la voiture a bilbao je pense que c'est énorme ! kurt a refait sont diff devant moi et c'est magique . ta une dureté que tu n'aura jamais avec un diff a billes et au pilotage ça motrice fort et au freinage c'est pas des couples coniques . Share this post Link to post Share on other sites
Posted July 1, 2009 Salut Merci!! Ha tu dis vraiment beau ?? La motricité a la sortie des virages comment ??? le bruit??? le comportement de la voiture avec répa. des masses car il y a du poids a l'avant il me semble , le centre de gravité , et le poid de la voiture ?? Excuse moi beaucoup de questions, mais en Suisse suis fermer pour info!! et suis vraiment interesser par voiture !! Merci fouadouille !! Share this post Link to post Share on other sites
Posted July 1, 2009 Bonjour a tous !! Chris de la Suisse nouveau sur forum ! Petite question ! Ces fameux diff a pignons dans bain d'huile qu'en pensez vous ???? car la je dois dir que je suis sceptique!!! Pour moi qui pratique aussi le TT 1/8e en plus du 1/10e, je pense que les diff. a pignons, ce sera vraiment un plus pour la fiabilité. C'est certes, plus contraignant aux niveaux des réglages (faut démonter le diff.) mais c'est quand même plus fonctionnel que nos différentiels a billes actuel. Pour moi, c'est un des plus de cette auto. :fou: Share this post Link to post Share on other sites
Posted July 2, 2009 Salut tout le monde !!! Vidéo sur youtube! ICFAazuVxHg oWDNfNkPf1M Share this post Link to post Share on other sites
Posted July 2, 2009 HEEEEEEE je crois que j'ai toutes les réponses a mes questions avec ces vidéos !!! ca fais mal pour la B44 !!!! c'est juste énorme !!! Share this post Link to post Share on other sites
