Posted February 8, 2015 Je n'ai pas un niveau de pilotage suffisant pour pouvoir comparer... Share this post Link to post Share on other sites
Posted February 19, 2015 #362573 Alu Steering Plate 4-Hole • For high-traction conditions • Increases steering precision • More predictable steering • Extra Ackermann positions • 4 holes • More forward Ackermann positions #364021 XB4 Alu Central Bulkhead • Increases strength • Increases reliability • Longer life • Premium Swiss 7075 T6 • Black coated • Laser engraved #363351 Alu Rear Upright - Right #363352 Alu Rear Upright - Left • Premium Swiss 7075 T6 • For high-traction conditions • Increases stability • Fine & precise roll center adjustment • More roll center positions • Wider wheelbase range adjustment • Black coated • Laser engraved #362234 Alu C-Hub 12° Right #362244 Alu C-Hub 12° Left • Premium Swiss 7075 T6 • Pre-set 12° caster • For high-traction conditions • Increases out-of-corner steering • Increases stability • Black coated • Laser engraved #364978 Composite Center Diff Spur Gear 78T / 48 #364981 Composite Center Diff Spur Gear 81T / 48 #364984 Composite Center Diff Spur Gear 84T / 48 • Precision molded • Specially-formulated composite material • Strong • Stamped for easy identification #365353 Alu Wheel Hub 12mm (2) #365354 Alu Wheel Hub 12mm (2)- Offset "-0.75mm" #365355 Alu Wheel Hub 12mm (2)- Offset "+0.75mm" #365356 Alu Wheel Hub 12mm (2)- Offset "+1.50mm" #365357 Alu Wheel Hub 12mm (2)- Offset "+2.25mm" #365358 Alu Wheel Hub 12mm (2)- Offset "+3.00mm" • Optional 12mm wheel hubs • Precision track width change • Swiss 7075 T6 aluminum • Lightweight design • Additionally drilled • Black coated • Marked for easy identification Share this post Link to post Share on other sites
Posted March 8, 2015 #361173 Graphite Front Upper Deck 2.0mm • Premium graphite material • 2mm thick • Adjusts chassis flex • Maximum strength • Long life • Combine with alu chassis #361103 Alu Chassis - Swiss 7075 T6 (3mm) • Premium Swiss 7075 T6 • 3mm thick • Super-strong • Extra-stiff • Increases cornering speed • Increases stability Share this post Link to post Share on other sites
Posted June 30, 2015 TE-125 Floating Servo Mount Set ( For Xray XB4'15 ) http://www.rc-tworks.com Share this post Link to post Share on other sites
Posted June 30, 2015 Je cherche à modifier mon XB4 2013 en version shorty. Je n'ai pas trouvé de tutoriels pour le faire proprement. Quelqu'un peut-il m'aider ? Merci Share this post Link to post Share on other sites
Posted June 30, 2015 Il me semble que c'est tout sauf trivial... sur le forum azur, Oliv l'a fait je crois... Paul Share this post Link to post Share on other sites
Posted June 30, 2015 Merci C'est quoi le forum azur ? Share this post Link to post Share on other sites
Posted July 1, 2015 Merci C'est quoi le forum azur ? un pseudo site de rc, copie de petitrc il y a 5-6 ans. Share this post Link to post Share on other sites
Posted July 1, 2015 Ah ok ! Sinon, savez vous si une carro d'un 2013 va sur un 2015 ? Share this post Link to post Share on other sites
Posted July 1, 2015 Ah ok ! Sinon, savez vous si une carro d'un 2013 va sur un 2015 ? La carro 2015 est plus large que la précédente. Share this post Link to post Share on other sites
Posted July 1, 2015 Il me semble que c'est tout sauf trivial... sur le forum azur, Oliv l'a fait je crois... Paul Share this post Link to post Share on other sites
Posted October 11, 2015 Je voulais juste avoir un retour d'info sur les amortsseurs, montage? utilisation? merci Share this post Link to post Share on other sites
Posted October 14, 2015 Puisque l on parle amortos Le traitement de la version 2016 a t il vraiment changé ( car suivant les photos ce n est pas les même ) et pas de communication de la par d xray a ce sujet Share this post Link to post Share on other sites
Posted October 27, 2015 Oui, le traitement est différent, et améliore la tenue dans le temps Share this post Link to post Share on other sites
Posted November 10, 2015 Sur 1/7/2015 22:33:56 , noarz a déclaré: C'est propre. Possible d'avoir les détails de la conversion ? Share this post Link to post Share on other sites
