Posted October 26, 2014 (edited) je suis en 21 dents avec mon 6,5 mais j'ai pas vérifier si le b44.3 garde le même rapport interne que le B44.2 avec les diffs à pignions... à voir Edited October 26, 2014 by anto-tt 1/10 ajout d'information Share this post Link to post Share on other sites
Posted October 26, 2014 tous les pilotes asso sont en 19 visiblement avec leurs 6.5 maintenant leurs piste ne sont pas comme les notres arf je regrette mon tableau avec les pignons/couronnes Share this post Link to post Share on other sites
Posted November 6, 2014 B44.3 Carbon Shorty Battery Strap B44.3 owners will love the eye-catching design along with the perfect fit and performance of our B44.3 Carbon Shorty Battery Strap. The Schelle design is a direct replacement for the B44.3 kit plastic unit, keeping the easy to use pivot ball and twist knob for removing the battery to charge. B44.3 Carbon Shorty Battery Strap Features: 1. 2.5mm CNC routed premium USA-made Carbon Fiber 2. Works with existing kit pivot ball and twist knob. No screws to remove. 3. Rigid and light at 4.7g. 4. 100% made in the USA. 5. Package includes 1 B44.3 Carbon Shorty Battery Strap and Schelle mini decal. SCH1103 B44.3 Carbon Shorty Battery Strap note: User may want to grind the lower surface of the twist tab to get the strap to sit lower for thinner batteries. Share this post Link to post Share on other sites
Posted November 11, 2014 PSM, partner of "PETITRC RACE", are proud to announce some new Product for Team Associated B44.3. PSM, partenaire de la PETITRC RACE, est fier de vous annoncer son dernier produit pour Team Associated B44.3 PSM's goal was to bring back the carbon fiber chassis to your B44.3 with a shorty LiPo configuration, in order to be competitive on low to medium grip surfaces as well. After weeks of intense development we are proud to finally release our Carbon Chassis Shorty Conversion for Team Associated’s B44.3. It includes two 5mm carbon battery trays fitted to keep your shorty LiPo batteries in place. Optional battery trays for saddle style LiPo batteries are available (#PS01687). This chassis is made to suit low to medium grip surfaces, however, it works on some high grip surfaces too. Our unique battery mounting system called AirMount is included as well. It was designed not to affect the chassis flex while keeping your battery in place. This system allows the chassis to bend both directions the same way so it can generate the ideal traction. It only weighs 14.5g fully assembled while retaining super strong. This complete set reduces the overall weight of the stock B44.3 for around 60 grams. That allows you to add balancing weights for getting the car perfectly set to your driving style or just keep it as light as possible. All included carbon items are precise machined by PSM in Germany from our authentic carbon fiber material which is truly premium quality, high impact resistant and semi-gloss looking. Features • Exclusive AirMount System. Unique battery mount without affecting chassis flex. • Inclusive Battery Trays. 5mm carbon trays designed for shorty lipo configuration. • Balanced Flex. Designed for low to medium grip surfaces (works on some high grip surfaces as well) • Lightweight. Total Saving = 60.0g / Chassis Plate (98.0g) / AirMount (14.5g) / Battery Trays (13.0g) • Authentic PSM Carbon. Premium quality material. High Impact resistance. Semi-gloss look. • Designed and precise machined by PSM in Germany. • RoHS tested and approved raw material. Included 1x Main Chassis Plate - Carbon 2.5mm 1x Battery Strap with PSM Logo - Carbon 2.5mm 1x Battery Tray R shorty configuration - Carbon 5mm 1x Battery Tray L shorty configuration - Carbon 5mm 1x Center Brace - Carbon 2.5mm 2x Short posts for AirMount - Aluminium 7075 2x Long posts for AirMount - Aluminium 7075 6x Threaded inserts for battery trays - Aluminium 7075 1x Screw set - Black Steel (12 Pieces) Share this post Link to post Share on other sites
Posted November 14, 2014 B44.3 10° ALLOY CASTER HUB SET (B44.2, B44.1) Heavy duty 7075 precision machined alloy caster hubs for the B44.3 (any B44). Update your B44.3 with essential vertical ball end mounting for quick roll center adjustments by adding or removing spacers. The included 2mm spacers sets the roll center at the stock geometry and the -10° caster hub is set at the stock angle. Polished and anodized in factory blue and laser etched for easy left right identification. Adjustable steering arm lockout settings. Allows for optional set screw placement against the hinge pin (4/40 set screw required). B44.3 STEEL SLIPPER DRIVE CUP (B44, B44.2, B44.3) New heavy duty spring steel slipper drive cup for the B44 series slipper clutch. With higher grip tracks and high power motors the stock plastic drive cups just wont do. Machined for lightness while maintaining strength these cups will get you through your race weekend without a worry. The cup includes a snap ring for secure yet easy acces to the drive pin. This drive cup works for either the front or rear of the slipper shaft. Includes 1 cup and 1 snap ring. exotek Share this post Link to post Share on other sites
Posted November 16, 2014 en etudiant la notice le train arriere ne tien au chassis qu avec trois vis!!!ce me parrait bien leger nan? Share this post Link to post Share on other sites
Posted November 16, 2014 Pas du tout, déjà c'est cinq vis puis ensuite maintenu par la platine supérieure. Ca fait depuis le B44 premier du nom que c'est comme ça, aucun risque de la perdre ça se saurait depuis le temps ;-) Share this post Link to post Share on other sites
Posted November 17, 2014 ben d apres ma notice c est que le train arriere est pas sur le chassis mais apres le chassis!!!merci pour l info Share this post Link to post Share on other sites
Posted November 19, 2014 Quel qu'un aurait un setup moquette merci Share this post Link to post Share on other sites
Posted November 21, 2014 Quel qu'un aurait un setup moquette merci regarde dans la section reglages, il y en a une. dommage que les pilotes francais ne partagent pas nouvelles pieces New Factory Team Parts for the B44.3 #9953 B44.3 battery strap for shorty packs. Now in stock! #9954 Aluminum Center Diff Cap for the B44.3 improves heat dissipation of the center diff, resulting in improved diff oil consistency throughout your run. #9955 12mm blue aluminum front hex conversion comes with longer roll pins (#9956). Use this 12mm hex conversion with Team Associated's new 61mm 4WD front wheels for the B44 series of vehicles. #9956 is a package of six replacement roll pins for the #9955 12mm front hex conversion. #9953 B44.3 FT Graphite Battery Strap, Shorty Available NOW #9954 B44.3 FT Front Aluminum Center Diff Cap Available Dec. 2014 #9955 B44 FT 12mm Front Hex Available Dec. 2014 #9956 B44 Front Hex Roll Pins, for #9955 Available Dec. 2014 Share this post Link to post Share on other sites
Posted November 22, 2014 question bete j ai deux cartons de roue avec goupillle pour l entrainement c est possible de faire comme sur le b44 original??enlever les exagonnes de roues? Share this post Link to post Share on other sites
Posted December 2, 2014 la section "durability" est a hurler de rire... Jason commence a prendre un peu trop confiance Share this post Link to post Share on other sites
Posted December 26, 2014 RDRP0246 - B5RM/MM Shock Spring Cup Aluminium +5mm Off-Set Set FUNCTION & DESIGN The B5 series aluminium spring cups in +5mm offset configuration are a direct replacement for the stock plastic cups and improve spring fitment and overall rigidity for optimised suspension performance especially on high-bite surfaces that put a lot of stress on the suspension. The parts are CNC-machined from aircraft-quality 7075-T6 aluminium, super lightweight at 1.65g per piece, they come blue anodised and laser-etched for that ultimate factory look. APPLICATION Designed to replace the kit's plastic shock cups with more rigid and more durable parts. SPECIFICATIONS - Material: blue anodised high-quality aluminium - Fits: Team Associated B5,B5M,B44.3 and all other AE 1/10 offroad cars using the bigbore shocks Avert Design Aluminum Spring Cups | B5 / B5M / B44.3 Product Overview Our popular Avert Aluminum Spring cups for the B5 and B44.3 offer you a true rigid surface with the added security that it won’t come off in those demanding conditions. This is accomplished by a unique angled slot design that adds another element of interference to keep the spring cup from popping off. If that wasn't enough, the fit is nice and snug on the shock eyelet to help prevent shock shafts from pulling out of the plastic shock end. The Avert spring cups add that extra security to your ride without sacrificing weight or putting a huge dent in your racing budget. Features Fits B5, B5M, B44.3. *Height equivalent to +5 Associated spring cup Unique angled slot design: Avert Aluminum Spring Cups add 2 elements of safety. A rigid aluminum spring cup won"t flex and spread open, slipping off of the shock end in a crash. The angled slot design adds another element of interference to keep the spring cups from popping off in a crash. The spring cup must lift completely off of the eyelet for removal. Tall inner perch to prevent spring from getting knocked off the spring cup in a crash. Smooth surface is easy to clean. No nooks and crannys for dirt to get trapped in! 1.3g each. Minimum Weight, Maximum Durability. 6061-T6 Aluminum alloy, precision CNC machined, black anodized with laser etched logo. Each package includes 4 spring cups and 1 AVID mini decal sheet. Share this post Link to post Share on other sites
Posted February 8, 2015 Un petit truc simple (surement connu) pour ceux qui cherche à obtenir l'équilibre droite-gauche. Share this post Link to post Share on other sites
Posted February 18, 2015 Factory Team B44 Aluminum Toe Plate (3 degrees) #9727 • Used for B44 series vehicles • Added strength • Improves corner speed and on-power traction Share this post Link to post Share on other sites
Posted March 15, 2015 question bete j ai deux cartons de roue avec goupillle pour l entrainement c est possible de faire comme sur le b44 original??enlever les exagonnes de roues? Salut , Oui il est toujours possible de mettre des jantes a aiguilles dessus . Il te faut simplement enlever l'hexagone de 12mm remettre la rondelle bleu des anciens b44 et remettre la goupille. Bien sur contrôler le jeu qu'il et caler correctement pour l'éviter. @+ced. Share this post Link to post Share on other sites
Posted March 24, 2015 Carbon Fiber Option For B44.3 During the 2015 Reedy Race of Champions, JConcepts debuted the B44.3 carbon fiber F&R top deck, servo and battery brace. This carbon fiber parts set is unique in looks, tough in durability and contributes to tuned flexibility which leads to a better handling vehicle. The top decks feature slotted locations which were added to free up the rigidness of the vehicle. More flex will contribute to a more confident driver who wants a more flowing drive out of the vehicle. In addition, the antenna mount was removed from the front top deck and placed on a new and included servo deck piece. The new position of the antenna mount is perfect for the popular servo mount location as well as convenient for the receiver and antenna wire. For racers choosing the new Silencer B44.3 body it also pulls the antenna mount out of the cab area and places it down on the side pod area similar to a 2wd buggy, cleaning up the entire look of the vehicle. JCO2443 To finish, JConcepts has included a matching battery brace along with hardware to directly fasten the battery in place for complete security. All carbon fiber parts are designed by JConcepts, produced with genuine 2.5mm material and machined to perfection. Features: · Original JConcepts design · 2.5mm genuine Carbon Fiber material · Confidence inspiring handling · Improved antenna mount location · Fasten down battery security · Aesthetic eye-candy JConcepts – B44.3, 2.5mm carbon fiber F&R top deck, servo and battery brace – 4 pc. Part# 2443 Share this post Link to post Share on other sites
Posted June 19, 2015 +5AE ALLOY SPRING PERCH SET (4) B5M, B44 Serial Number:1518 Machined, polished and anodized alloy +5 off set spring perch set for Associated B5, B5M and B44 big bore shocks. Extra milling for a lightweight design with reinforced strength of cnc cut aluminum and a snug fit to reduce the chance of losing a perch. Milled holes also help reduce debris from collecting inside. Direct fit on the B5, B5M and B44.3 Set of 4. +9AE ALLOY SPRING PERCH SET (4) B5M, B44 Serial Number:1519 Machined, polished and anodized alloy +9 off set spring perch set for Associated T5M big bore shocks. Extra milling for a lightweight design with reinforced strength of cnc cut aluminum and a snug fit to reduce the chance of losing a perch. Milled holes also help reduce debris from collecting inside. Direct fit on the T5M! Set of 4. Share this post Link to post Share on other sites
