Posted January 15, 2015 This Ripmax Micro Stunt Car is perfect for indoor use. With the built in moving chassis suspension system this car is more than up to use on home made jumps and racetracks. The battery is built in and can be charged from the transmitter with ease. The 2.4GHz transmitter has 2 settings. Like a traditional RC car you can use the throttle and steering normally but when you enter scale mode it has optional digital gears. Gears 1-5 are indicated by LED lights on the transmitter and each limit the power as you use them. Set it in first gear and get used to the controls then 'let it rip' as your power increases when you go up the gears! • Includes 20 course cones (10 red & 10 blue) • Scale speed setting with digital gears • 2.4GHz Radio • Moving chassis suspension system • Available in Blue, Red or Black Requires: 4x 'AA' Batteries for the transmitter Download the Manual in PDF Format (.PDF) Specifications Modulation: 2.4GHz Length: 120mm Height: 49mm Weight: 60g Radio System: 2 Channel (Inc.) Wheel Base: 75mm Width: 83mm http://www2.ripmax.net/Item.aspx?ItemID=C-RMX0040&Category=040-110 http://www2.ripmax.net/Instructions/C-RMX0040.pdf Share this post Link to post Share on other sites
Posted January 15, 2015 autres http://www2.ripmax.net/Item.aspx?ItemID=C-RMX0045&Category=040-110 Share this post Link to post Share on other sites
