ben44
TeamC TC02C V2
8 posts in this topic
Voilà les 1ère du nouveau Tc02C.
Le diff à pignon est d'origine avec la possibilité de mettre un diff à bille.
TC02C Evo 1/10 2WD Mid Motor Buggy
Cab Forward Body
With 8mm Longer Chassis
12mm Big Bore
Aluminum Arm Mount
Rear Sway Bar
New Design Chassis Fits Shorty Or Saddle Pack Battery
Mid Motor Design
Gear Diff
TU0249 TC02C Evo Conversion Kit
Incl :
Gear Diff
CNC Motor Plate
TC02C Evo Chassis
Outdrive
Gear Box
Gear Box Support
Battery Plate
Rear Chassis
TC02C Evo Body
TC02CEVO Comp. Buggy
The TC02CEVO solves its successful predecessor the TC02C. The TC02CEVO offers many novelties. Now, the buggy is driven by a gear differential. The new designed battery mount prevents slipping of the batteries. The new chassis plate is designed to use shorty or saddle-pack LiPo batteries.
14mm aluminum Big Bore shocks with bleed caps
8mm longer fibre-reinforced plastic chassis
Aluminum suspension arm holder front
3mm aluminum motor mount
Gear differential 52T
Front cab body
10.9 steel screws
2 aluminum idle gears 28T
Complete ball bearings
Fibre-reinforced plastic main gear 80T
Swaybar 1.2 rear
Through the narrow chassis layout, shorty and saddle pack batteries find their place. A newly designed battery holder prevents the slipping of the batteries.
This gear box is the heart of the TC02CEVO. Mounted on a aluminum motor plate, the 3 gears take over the motor power and bring it to the gear differential.
Multi positions in combination with 14mm Big Bore shocks form an excellent offroad suspension. The hard anodized threaded housing serve strength and adjustability under any condition.
J'adore ce chassis...
Si je devais changer mon TM2 ce serait ça sans hésiter ...
Mon seul regret est qu'ils n'aient pas adapté le système de cale de pincement/antisquat sur le train arrière.
Le support amorto Arrière "semble" fragile au niveau du support d'aileron ...
TC02C Evo Carbon Fibre T-Plate
New Carbon T-Plate for the TeamC TC02C Evo
Machined from a solid piece of 6mm Carbon Fibre to give the ultimate accuracy, rigidity and strength.
It's been designed to utilize the RF alloy hanger (TU0221) from the Rear Motor TC02 which gives greater strength and the ability to adjust anti-squat at the front by using spacers.
Available as a T-Plate only or with the RF Hanger included
Pre-Order now open - due in stock 6th July 2015
ILR5021
TC02C Evo Carbon Fibre T-Plate with RF Hanger
ILR5021+Hanger
insidelineracing.co.uk
Kev Lee en avait marre de peter des plaques AR... :D
