Posted August 31, 2014 salut, en quelle matière sont fait les couples coniques s'il vous plait? merci Share this post Link to post Share on other sites
Posted September 11, 2014 support carbone en 4mm par azarashi AZ-0042 AZ-0043 AZ-0044 Share this post Link to post Share on other sites
Posted December 5, 2014 3/32" Tungsten Carbide and Ceramic Thrust Set (12) This is a combination set including 12 pcs 3/32" Tungsten Carbide High Precision Balls and our Ceramic Caged Thrust Bearing for Associated/TLR. Schelle 3/32" Tungsten Carbide High Precision Balls are the perfect upgrade for the ball differential in your Associated or TLR vehicle. These are the highest precision possible, with each ball measuring the same diameter at all points within 10 / 1,000,000 ths of an inch. This precision give you the smooth feeling diff like a cermic diff ball, but with the perfect hardness and ease of setting that comes with a Tungsten Carbide diff ball. The Schelle Ceramic Caged Thrust Bearing for AE and TLR gives the diff maximum smoothness and is easy to build. The 6 caged ceramic balls run on a hardened, grooved ring to keep the diff smooth longer than anything else we've found. Fits the following vehicles: B44.2, B4.2, T4.2, Centro C4.2, Centro T4.2, SC10.2, TLR 22-4. Each package contains 12 pcs 3/32" Tungsten Carbide High Precision Balls and 1 Ceramic Caged Thrust Bearing inside of a mini snap case along with a Schelle mini decal. Pro Tip: If you encounter an issue with the diff screw bottoming before the diff is tight, add a flat kit thrust washer over the diff screw (closest to the screw head) to act as a spacer. In some cases the shoulder on the diff screw can bottom out due to the smaller thickness of a caged thrust. Share this post Link to post Share on other sites
