Posted January 8, 2012 http://www.youtube.com/watch?v=8p4WYx3lqM4 The TURNIGY 1/18 Mini Go-Kart is a real blast to drive, with its low center of gravity and ultra sticky TruRubber* tyres which keep the kart turning sharply. A powerful metal gear servo is included with kart to keep the steering precise and quick, while the non differential rear tyres lay rubber on each corner! The entire floor pan is made of 2mm carbon fiber sheet which offers a very rigid chassis and true race kart handling characteristics. The wheels are alloy, as well as the steering arms and motor mount offering light weight durablility. You will need a 18A ESC, an 20 size inrunner motor around 4500-4800Kv, a 2CH transmitter/receiver and 2S 800mah LiPo battery. Stickers are included, but the driver is unpainted so you can create your own race livery on the driver. Spec. Length: 190mm Width: (F)129mm / ®139mm (measured at edge of tires) Wheelbase: 120mm (axle to axle) Height: 139mm Ground Clearance: 5~6mm Tire Size: (F)26×15mm / ®27×21mm Required. 18A Car ESC Receiver/Transmitter LiPo: 2S 800mah (31.5mmx30mmx60.5mm max size) Included: Mini Go-Kart Pinion Zip Ties Double Sided Tape Spare Screws TruRubber: TURNIGYs very own super-soft rubber compound that sticks to road surfaces better than standard street tires. http://www.youtube.com/watch?v=3sXlNgr2goo&feature=related http://www.flickr.com/photos/fusselflitzer/sets/72157628044807486/ https://plus.google.com/photos/104656736936976952947/albums/5667486495712981025?banner=pwa#photos/104656736936976952947/albums/5667486495712981025 http://www.youtube.com/watch?feature=player_embedded&v=xdWjk7nWT9Q#! Share this post Link to post Share on other sites
Posted January 8, 2012 source http://www.rcgroups.com/forums/showthread.php?t=1539104 Share this post Link to post Share on other sites
