Posted December 5, 2011 il existe un tres bon servo spektrum (H5010) de la meme taille que celui d'origine 4,5kg pour 0,11s pigions metal Share this post Link to post Share on other sites
Posted December 21, 2011 Phat Bodies - Exclusive first pictures of new Losi Mini 8ight body shells What an afternoon we have had over at ORRC H.Q. I virtually attacked the postman's neck today when he finally trod the icy path up to my door. He was carrying a small brown cardboard box. The box had started its journey 2 days prior at Phat Bodies production studio in Bristol. Si Osbourne had lovingly packed this little parcel of dreams and sent it up to the chilly climbs of the Black Country for us to grab some first impressions on its contents just for you 1/16th off-road fans. We thought the only way we could really do the micro scenes excitement justice was to get in the studio and take our very own super fresh photographs. The recent release of the Losi Mini 8ight has spurred Si and the hard working team over at Phat Bodies to create 3 new lids that are not just designed with aesthetics in mind, but feature some amazingly well designed body contours for maximum air flow organisation and incredible space for electrical installation. Share this post Link to post Share on other sites
Posted December 25, 2011 Papa Noël m'a apporté le mien : je t'aime Papa Noël :drunk: Il est EXTRA !! Ca envoie bien, ça tourne, c'est stable... que du bonheur !! Quelqu'un l'a-t-il essayé en lipos 3S ? Si oui, moteur, contro et trans tiennent-ils bien le coup ? Merci. Stéphane. Share this post Link to post Share on other sites
Posted January 30, 2012 Bonjour, Pouvez vous me communiqué la ref des pieces asso a mettre dessus pour la fiabilité Merci beaucoup les pros :blush: Share this post Link to post Share on other sites
Posted January 30, 2012 les chappes d'amortos, avec les tonnes de pieces de T4 que tu as il doit bien y en avoir Share this post Link to post Share on other sites
Posted January 30, 2012 J ai pas essayer en 3s mais en 2s ça envoi grave je trouve que ça suffit en 2s et en plus les 2S j en trouve a 17€ donc ça le fait bien Share this post Link to post Share on other sites
Posted February 2, 2012 voici mon mini eight bientot avec une caro perso Share this post Link to post Share on other sites
Posted February 2, 2012 d'ou vien la barette d'accu carbone? Share this post Link to post Share on other sites
Posted February 2, 2012 la barrette d'accus c est moi qui l ai faite titi Share this post Link to post Share on other sites
Posted February 2, 2012 j ai essayer de refaire un peu la forme de la carro avec la barrette Share this post Link to post Share on other sites
Posted February 14, 2012 Bonjour à tous, Je suis ce post avec intérêt! Ce mini 8ight me plaît beaucoup! Venant du TT 1/10 électrique, je me demandais si je devais laissé de côté tous mes accus Lipo 1/10 ème à cause de leur taille? Ils sont tous en hard case ( utilisés sur un T4.1 ), en 2S, capacité mini 3600 et maxi 5600. Faut-il prévoir un tout petit servo? Enfin, pour remplacer le combo d'origine, y-a t-il une taille maxi pour le contrôleur? Le moteur est-il de type 540 ou plus petit? Merci d'avance de vos réponses et de vos éclaircissements! Cordialement Michaël Share this post Link to post Share on other sites
Posted February 14, 2012 rien de compatible accu plus petit servo aussi moteur aussi mais d origine il marche très bien pas besoin de mettre un autre moteur ou controleur pour les accus lipo ça vaux environ 17€ Share this post Link to post Share on other sites
Posted February 20, 2012 J'ai commandé des 3S 1300 en 45C : dès que testés je vous fais signe sur mes impressions ! Stéphane. Share this post Link to post Share on other sites
Posted March 6, 2012 Bonjour , Quelqu un peut me dire quel type de pignon c'est sur le mini eight ? (64dp , 48dp , ou autre ...) Merci ;-) Share this post Link to post Share on other sites
Posted March 9, 2012 a verifier mais je crois que c est du 48dp Share this post Link to post Share on other sites
Posted March 9, 2012 jamais demonté la couronne/pignon, ca marche telement bien comme ça a mon avis oui 48 mais a verifier Share this post Link to post Share on other sites
Posted March 10, 2012 Merci pour vos reponse, a l'oeil je n'arrivais pas a voir, effectivement il marche tres bien comme sa je ne compte pas modifié...Mais par curiosité.. Voici quelque photos du mien avec carro pirhana phat bodies que fraichement peinte par mes soins, dites moi ce que vous en pensé :=): Share this post Link to post Share on other sites
Posted March 10, 2012 sympas la peinture, la forme de la carro est "agressive", elle porte bien sont nom Share this post Link to post Share on other sites
Posted June 5, 2012 jme suis monté des ptits amortos pas degeu et en plus ça marche bien Share this post Link to post Share on other sites
Posted June 14, 2012 une super nouvelle pour les pocesseurs de mini8 RPM nous sort des triangles un bon investissement a faire http://www.rpmrcproducts.com/products/losi/minitpts.htm#mini8arm Share this post Link to post Share on other sites
Posted June 25, 2012 salut petits run hier a la piste en terre de lacanau en ligue 15, avec un pote (le M8 orange) malgrés une piste "defoncée" pour l'echelle de la voiture super comportement. Share this post Link to post Share on other sites
Posted June 27, 2012 Salut ,quel sont c est amortisseur que tu a montée sur le mini Losi blanc ? À tu trouver un mellieur comportement ? Share this post Link to post Share on other sites
Posted June 27, 2012 les amortos losi "hard", ils sont referencés sur leur site. j'ai trouvé du changement oui mais plutot avec le changement d'huile plus souple que d'origine, apres ça ne doit pas changer grand chose a part le plaisir de moter de belles pieces Share this post Link to post Share on other sites
