Posted May 11, 2015 TRF Series No.188 TRF211XM Chassis kit Item No: 42288 June 20, 2015 release List price: 72,144 yen (66,800) ★ It is a 2WD buggy for the expert. ★ high strength, adopting a resin Rowadekki that were molded excellent material with high impact resistance with a special recipe. To balance the bending rigidity at a high level, and demonstrate a stable ride in all road surface. ★ Equipped with big bore aeration damper around the foot. ★ low profile servo is used, straight pack battery also can be mounted. Share this post Link to post Share on other sites
Posted May 11, 2015 42288 1/10 R/C TRF211XM Chassis Kit Tamiya is delighted to announce the latest evolution in its 2WD R/C buggy series. The TRF211XM chassis is a high-spec unit designed to compete in top-end racing, with the grip and road holding to take on the very best that this seriously competitive scene has to offer. It features a whole host of newly-designed parts, including a resin lower deck specially produced to offer sublime balance. This seriously speedy buggy is unfazed by bumpy,undulating off-road surfaces. Featured Components - TRF211XM Lower Deck - Rear Stiffener Carbon Battery Stiffener (2.0mm) - Carbon Battery Plate (2.5mm) - Aluminum Battery Stoppers - Carbon Rear Damper Stay (4.0mm) - Brass Suspension Mount Rear F - Aluminum Gearbox (choice of ball and gear diff units) - Big Bore Dampers (Front/Rear) - Drive Shafts w/Axle Rings - Cooling Pressure Plates - Lightweight Body & Rear Wing About the Model • This is a 1/10 scale R/C 2WD buggy chassis assembly kit. • New lightweight resin bathtub chassis offers excellent balance of rigidity and flexibility, to master off-road surfaces. It can be used with a wide variety of battery pack types. • Rear stiffener and battery stiffener parts are attached to each other during assembly, improving rear rigidity. • 4-wheel double wishbone suspension is paired with big bore aeration dampers for supreme performance. • Also includes lightweight 0.6mm thickness body from Item 84374 and wing. • Comes with durable brass Rear F suspension mount. • Universal drive shafts are secured using axle rings. • Slipper clutch pressure plates feature indentations to allow more efficient cooling. • Features an aluminum gearbox with a choice of ball or gear differential units. • For use with separate type battery pack, or a combination of straight type battery pack and low-profile servo. Share this post Link to post Share on other sites
Posted May 18, 2015 42288 TRF211XM Chassis Kit This is the latest evolution of Tamiya's flagship 2WD racing buggy. The TRF211XM chassis is a high-spec off-road buggy designed to compete in top-end racing, with the grip and road holding to take on the very best that this seriously competitive arena has to offer. It features a whole host of newly-designed parts, including a plastic lower deck specially produced to offer sublime balance. This seriously speedy buggy is unfazed by bumpy, undulating off-road surfaces. Featured Components: • TRF211XM Plastic tub Lower Deck • Carbon Battery Plate (2.5mm) • Brass Suspension Mount Rear F • Big Bore Dampers (Front/Rear) • Lightweight Body & Rear Wing • Rear Stiffener • Aluminum Battery Stoppers • Aluminum Gearbox (choice of ball and gear diff units) • Drive Shafts w/Axle Rings • Carbon Battery Stiffener (2.0mm) • Carbon Rear Damper Stay (4.0mm) • Cooling Pressure Plates Product Specifications Special feature 1: New lightweight resin bathtub chassis offers excellent balance of rigidity and flexibility. Special feature 2: It can be used with a wide variety of battery pack types including separate type battery pack, or a combination of straight type battery pack and a low-profile servo. Special feature 3: Rear stiffener and battery stiffener parts are attached to each other during assembly, improving rear rigidity. Special feature 4: 4-wheel double wishbone suspension is paired with big bore aeration dampers. Special feature 5: Includes lightweight 0.6mm thickness body from RC Body set Item 84374 and wing. Special feature 6: Comes with durable brass Rear F suspension mount. Special feature 7: Universal drive shafts are secured using axle rings. Special feature 8: Slipper clutch pressure plates feature indentations to allow more efficient cooling. Special feature 9: Features an aluminum gearbox with a choice of ball or gear differential units. http://www.tamiyausa.com/coming-soon/radio-control-kits-30/off-road-buggies-36450/rc-trf211xm-chassis-kit-42288 Share this post Link to post Share on other sites
