Posted January 3, 2008 B44 upgrades coming soon in 2008. We will soon have avaiable a range of upgrades for the new Associated B44, keep checking the website for more info. Share this post Link to post Share on other sites
Posted January 3, 2008 On attends effectivement les pièces mais c'est pas pour tout de suite : I will be making shock towers for the B44 plus other upgrades as per the attached photo ;-) The photo is for private viewing only and is not to be published. We are testing at the moment but should have something ready in the next few months. Share this post Link to post Share on other sites
Posted January 3, 2008 Cool, et peut-être une petite conversion S4 pour le B44??????? Share this post Link to post Share on other sites
Posted January 3, 2008 oui mais a quel prix ?? surement trop cher Share this post Link to post Share on other sites
Posted January 4, 2008 Je suis en contacte via messenger avec jonathan de chez atomic je peut vous dire juste 1 chose c'est soyez encore un peut patient Vous serez pas dessus Share this post Link to post Share on other sites
Posted February 11, 2008 Vue sur oOple Les premieres photos de la carro du S44 Atomic Carbon Share this post Link to post Share on other sites
Posted February 11, 2008 First pictures of the Atomic-Carbon B44 optional body that is used with the Atomic-Carbon B44 optional Carbon Fibre Tub Chassis. small details are still being refined. this is a prototype. The front and rear towers have been shaped to allow airflow over the body and not get blocked by the tower. The body is lower than the S4 yet there is plenty of room for full size servo's, recievers and Fan mounted TC style speed controllers Amazing Paintwork by DragonPaints -> check out some more of his work by visiting the link to the right hand side. http://www.doughtyuk.net/index.php?ind=news&op=news_show_single&ide=6 Share this post Link to post Share on other sites
Posted February 13, 2008 MON S4 Voila apres une premiere soirée de preparation hier MODIFICATION POUR METTRE LES TRIANGLES TAMIYA 501X apres mise en place de la visserie NORTH TEC RACING top qualité, mise en place de la roue libre, cardant Shiny pour un peut de BLING BLING, mise en place des amortos LOSI, mise en place du servo.... Pour demain a venir les roulette bleu asso pour tenir la barette d'accus, instalation du vario et moteur( LRP TC SPEC ET LRP 5.5 BRUSHLESS rotor sintered 13mm ou 12,5 mm avoir celon la piste, Souder mes nouveaux pack en 2X2X2 :? , et reception demain matin de ma carro BY MASS et demain fin d'aprem direction LAON avec BRUNO HERMANS ET TOUTE LA CLIC pour les premier essais de la bete PHOTO DE MA CARRO REçU A L'INSTANT PAR MASS Share this post Link to post Share on other sites
Posted April 23, 2008 Atomized B44 shock towers / Direct fit onto the B44 Share this post Link to post Share on other sites
Posted May 15, 2008 Les supports AV et Ar devraient arriver avant fin de semaine Share this post Link to post Share on other sites
Posted July 16, 2009 Au sujet des supports atomic carbon pour B44, petite curiosité de ma part... La structure "interne" du matériau (quand on regarde sur la tranche) a l'air différente de celle des pièces d'origine (à gauche le support Atomic, à droite le support Asso) : Quelques fibres des différentes couches ont l'air d'être entremêlées, alors que sur celui d'origine elles sont toutes alignées... C'est pour renforcer la liaison entre les couches (qui sont simplement collées entre elles si je ne m'abuse) pour éviter qu'il se transforme en "mille feuilles" sur un choc? Ou alors c'est juste provoqué par la découpe du carbone et donc c'est superficiel... Quoi qu'il en soit, esthétiquement c'est sympa Share this post Link to post Share on other sites
Posted July 22, 2009 Bonjour, je cherche mais je trouve pas ou l'on peut acheté les support atomized B44 (S4). Quelqu un sait ou je peut en acheteé?? merci Share this post Link to post Share on other sites
Posted July 22, 2009 j'adore!!!!!!!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
Posted July 22, 2009 Bonjour, je cherche mais je trouve pas ou l'on peut acheté les support atomized B44 (S4). Quelqu un sait ou je peut en acheteé?? merci Je crois que tu peux les commander chez ... - - ... Share this post Link to post Share on other sites
Posted July 22, 2009 Bonjour, je cherche mais je trouve pas ou l'on peut acheté les support atomized B44 (S4). Quelqu un sait ou je peut en acheteé?? merci Alors je précise c'est ou les support Atomized B44 pour ''B44'' ou bien les support de S4 c'est pas du tout la meme chose ;-) Share this post Link to post Share on other sites
Posted July 22, 2009 Vu que c'est rubrique b44 je pense que c'est pour b44, ce que j'e stocke sans pb avec d'autres pièces AC; Le reste, moins demandé, c'est sur commande Share this post Link to post Share on other sites
Posted July 22, 2009 ok merci , j'apelerais dès que je peu Share this post Link to post Share on other sites
Posted July 28, 2009 L'Atomized B44 Red De Laurent Lepage qui est français Share this post Link to post Share on other sites
Posted July 28, 2009 Superbe en effet, mais... où est le récepteur radio???? Et aussi, quid de la rigidité du châssis, sans platine supérieure? Share this post Link to post Share on other sites
