Posted March 4, 2015 MT-4S 40 Years Sanwa Edition incl. 2 Receivers, Aluminum Wheel 40 years Sanwa – the limited special edition of the MT-4S with new features. Art. no.: 101A31575A This is Sanwa MT-4S 40th Anniversary Edition Radio. In honour of the 40th anniversary of the company, Sanwa releases a special edition of the MT-4S! Therefore, the engineers upgraded the “M12 in small size” with new technical and visual features. The MT-4S 40 Years comes in a special black piano lacquer design and with grip plates designed accordingly, while the steering wheel is made from aluminium. Depending on the receiver you choose, telemetry data like motor / engine temperature, rpm, drive battery or receiver battery voltage can be displayed and stored to the computer also with the MT-4S 40 Years. The telemetry data is displayed on a large full-dot LC-display. Due to the integrated background illumination, improved legibility of information and set-up is guaranteed. The Sanwa Vortex Zero Brushless speed control can be programmed directly from the transmitter as the MT-4S features the SSL function of the M12. SSL Supported (Sanwa Synchronized Link) 4-Channel 2.4GHz FH4T Digital High-Response Telemetry System with Advanced Programming Backlit LCD Screen Allows You to Easily View Programming Options and Telemetry Data in All Types of Conditions High-Power FH4T Technology Provides the Best Reception and Connectivity, Giving Racers Added Assurance 4 Cell Dry Battery Holder for Lighter Weight - Also Accepts Optional NiCd/NiMH or 2S LiPo/LiFe Battery Packs 18-Model Memory Telemetry Logging Channel-Set Menu Servo Reversing Steering, Throttle and Brake Dual Rate End-Point Adjustment Exponential and ARC Adjustment Servo-Speed Adjustment Anti-Lock Braking Throttle Offset Lap and Interval Timers Total, Best and Individual Lap Display Four-Wheel Steering Mixing Dual Throttle Mixing w/Dig & Burn Normal, SSR and SHR Servo Modes Center or Parallel Trim Types MT-4S specification: Output Power: 100mW Nominal Input Voltage: 4.8v to 7.4v Operating Voltage Range: 4.0v to 9.6v Weight: 388g Frequency: 2.4GHz FHSS Modulation Type: FH2, FH3, FH3F, FH4T, FH4FT RX-472 specification: Nominal Input Voltage: 3.7v to 7.4v Weight: 0.23oz (6.6gr) Dimensions: 30.0 x 23.3 x 14.0mm Frequency: 2.4GHz FH3/FH4T Selectable Via Transmitter Fail Safe Support: Yes (All Channels) Battery Voltage Fail-Safe Limit: 3.5-5.0v (FH3) / 3.5-7.4v (FH4T) RX-471 (Dual ID) specification: Frequency: FHS 2.4GHz Power supply: 4.8v - 7.4v Dimensions: 30mm x 23.3mm x14mm Weight: 6.6g Sanwa MT-4S 2.4GHz 40th Anniversary Transmitter x1 RX-471 (dual id) receiver x1 RX-472 receiver x1 SRM 102 servo x2 40th Anniversary Carrying Bag x1 Switch x1 Battery holder x1 Extra Handle Grip x1 Manual https://www.lrp.cc/en/products/coming-soon/produkt/rx-461-empfaenger-fuer-mt-4-fhss-4t/details/ http://www.lrp.cc/en/products/vtec-batteries/transmitter-batteries/produkt/lrp-vtec-lipo-3000-tx-pack-sanwa-m12mt-4exzes-xsd-10g-tx-only-74v/details/ https://www.lrp.cc/fileadmin/lrp_pdfs/10/101A31575A-1.pdf http://www.airtronics.net/index.php/radios-receivers/2-4-ghz-surface-radios-1/airtronics-mt-4s-40th-anniv-w-case-472-471d-id-rx.htm http://www.sanwa-denshi.com/rc/car/propo/mt-4s.html Share this post Link to post Share on other sites
