Posted April 6, 2013 Salut J'ai toujours roulé avec ces courroies pas de soucis Niveau tension elle n'est pas tendue à fond mais ne bouge pas... Share this post Link to post Share on other sites
Posted April 6, 2013 (edited) Salut J'ai toujours roulé avec ces courroies pas de soucis Niveau tension elle n'est pas tendue à fond mais ne bouge pas... OK merci... Edited April 6, 2013 by kistof Share this post Link to post Share on other sites
Posted May 7, 2013 Des retours de pilotes utilisant la eryx en France.comportement ,usure ou autre je suis preneur de tous renseignement. Share this post Link to post Share on other sites
Posted July 18, 2013 Serpent 411 Eryx, new optionals Shiping before end july or even before. Share this post Link to post Share on other sites
Posted December 15, 2013 Julian Borowski au gp3f http://www.mrc-longwy.fr/?p=1086 Share this post Link to post Share on other sites
Posted January 25, 2014 Bonjour , étant nouveau s411 , où commandez vous vos pieces en france autre que les ".de" avec leur 30e de port , car trouver un site avec des rtr et courroie ok mais chapes boules axe etrier fusée etc..... Merci Benjamin Share this post Link to post Share on other sites
Posted April 24, 2014 Serpent is about to introduce the strongly developed 411-ERYX 3.0 soon. Key NEW features: 2mm coated and laser engraved 7075 T6 aluminium chassis; dark grey anodised with ERYX 3.0 logo, lowered sides for optimal flex, fully symmetrical for even flex lighter lower bearingblocks front and rear indentical new type lower CG 7075 T6 motormount, centrally mounted seperate bushings to support the top-plate front and rear, to influence flex as needed lightweight aluminium spool with blades v2 type hard composite all around: wishbones, uprights, castorblocks, steeringblocks v2 hard composite wishbones with one central hole for shock mounting rear anti-roll bar mounted in front of rear arm double joint cardan shaft v2 with clips brackets standard : 3.5/ 0.5 split blocks in the rear, 2.0/ 0.5 in the front New material shock-O-rings Lightweight anodised aluminium camberlinks Lightweight anodised aluminium trackrods Lighter composite anti-roll bar centering front and rear ERYX 3.0 set-up sheet Detailed news and images to follow end april 2014. ERYX 3.0 starts shipping 1 may 2014 ! Team Serpent Share this post Link to post Share on other sites
