I-105 b5m conversion kit, mid motor only
3 posts in this topic
NEW INFINITY LINE FROM X FACTORY
DO THE MATH TO HOP UP YOUR RIDE
X Factory introduces a new line of parts called “Infinity By X Factory.”
For ten years X Factory has been the most innovative company in all of off-road R/C, first introducing the X – 5 in 2004 and following that in 2006 with the first mass produced mid-motor buggy, the X – 6. X Factory has won National Championships in nine different countries.
Now X Factory’s engineering genius Paul Sinclair turns his talents to other cars as we introduce the Infinity By X Factory line. These are not X Factory Conversion Kits which turn your existing AE car into an X Factory car; rather Infinity By X Factory are hop-ups that improve performance in other brands. First up is a new carbon fiber chassis for the B5M, and the line will be expanded soon with shock towers, new steering systems, and other innovative products that take your car to the next level. Do The Math -- It’s like a Squared version of your current car.
The Infinity carbon fiber chassis gives the B5M lots more flex and tunability. Drivers report both much better cornering and increased forward bite on all surfaces. Rough tracks require more flex, so loosen some or all of the side deck screws on the Infinity chassis. The forward screws affect front flex, while the rear ones work on the back end. Loosen a half turn, or take them entirely out – which ones you do and how much you do tunes the car. On smoother indoor tracks tighten the side decks down.
The new Infinity By X Factory CF chassis kit is available right now at fine hobby stores world-wide, with a suggested retail price of just $99.00! The I105 kit is complete with the CF chassis, all the other CF parts, aluminum stand-offs, hardware, and those great X Factory instructions. Each part is also available separately for spare parts.
B5M owners can now Do The Math! Watch for other Infinity By X Factory items to appear soon.
Kit includes everything needed to install X Factory's Infinity CF chassis on your B5M. Includes all CF pieces, hardware, and instructions to disassemble the B5M then re-assemble. Your car will be 70 GRAMS LIGHTER and will have much more chassis flex for greater corner speed and better forward traction. Flex can be tuned by tightening or loosening bolts on the side decks and chassis brace.
Features
  • Totally dialed CF look – nothing else like it for your B5M.
  • 70 grams lighter than the aluminum chassis car. Great in all classes, especially stock.
  • Adds chassis flex. Aluminum chassis is too stiff for most off-road racing.
  • No more tweak. CF absorbs inputs and returns to straight.
  • Increases side-bite and forward-bite. Faster than the aluminum chassis through bumps too.
  • Tunable side decks allow flex adjustment for any track surface, from dusty blown out to high bite indoors.
  • All batteries which fit the B5M will fit your new CF chassis.
  • Just $99.00 for the entire Kit!
  • Replacement parts available separately
XF-I103 Side Deck Spacers, CF, B5M, 2 per pack
XF-I102 Side Decks, CF, B5M, 2 per pack
XF-I101 Chassis, CF, B5M
XF-I104 Battery Spacer, CF, B5M
XF-6808 3mm x 20mm, Stand-Offs, Hex, female/female, 2 per pack
XF-6807 3mm x 8mm, Spacer, Round, 2 per pack
