Posted September 19, 2011 (edited) <img src="http://www.petitrc.com/gallery/files/losb0224_01.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" /> 1/14 Scale Mini 4WD Brushless Buggy Based up on the ROAR-Championship-winning 8IGHT™ buggy, this brushless-powered prodigy is the ultimate mini buggy. Its 1/14-scale size allows it to handle tougher terrain while mastering the outrageous power and speed from the brushless system. Better still, the Mini 8IGHT comes with everything you need to get started, including transmitter, rechargeable NiMH battery pack and charger. Experience the thrill of driving a Mini 8IGHT today. <img src="http://www.petitrc.com/gallery/files/3039-losb0224_04.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" /> SPECIFICATIONS Length: 292mm (11.49 in) Width: 204mm (8.03 in) Wheelbase: 186mm (7.32 in) Height: 110mm (4.33 in) at ride height Weight: 0.98 kg (2.15 lb) with battery Motor: 4500Kv brushless motor Speed Control: Brushless Radio: Spektrum™ 2.4GHz DSM Technology Batteries: 7.2V NiMH with EC2™ connector Kit/RTR: Ready-To-Run (RTR) Shock Type: Aluminium, threaded, oil-filled Body: Custom decorated available in 2 colors Tire Type: Mini Kingpin™ Buggy Ball Bearings: Complete <img src="http://www.petitrc.com/gallery/files/3039-losb0224_08.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" /> FEATURES • Water-resistant brushless ESC • 4500Kv brushless motor • Spektrum SR300 receiver with 2.4GHz DSM technology • 7.2V 1100mAh NiMH battery pack with EC2™ connectors • 4WD shaft-driven drivetrain • Front and rear metal gear differentials • Mini servo with saver • Aluminium, threaded oil-filled, coil-over shocks • Heavy duty, 2.5mm anodised aluminium chassis • Mini Kingpin™ treaded tires • 2.5mm aluminium shock towers • 12mm wheel hexes • Aluminium motor mount • Heavy-duty adjustable turnbuckles • Chassis dirt guards <img src="http://www.petitrc.com/gallery/files/3039-losb0224_10.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" /> Source: Horizon Hobby Edited September 19, 2011 by rcpassion Share this post Link to post Share on other sites
Posted September 21, 2011 il a l air super sympa ce mini eight vous en pensez quoi? qui peut mettre des photos merci titi Share this post Link to post Share on other sites
Posted September 21, 2011 oui les premieres video sont plutot sympas Share this post Link to post Share on other sites
Posted November 17, 2011 chassis reçu et demonté/remonté pour faire un petit check Tres belle qualité, reste a voir demain sur la piste seul le servo est un peux cheap avec un retour au neutre pas tjrs top mais avec 2 ou 3 coups de dremel je pense que l'on peux mettre un servo low profile de 1/10 quelques photos demain Share this post Link to post Share on other sites
Posted November 17, 2011 Salut châssis reçu et essayer hier c est de la balle ça se pilote comme un tt1/10 ça braque bien ça saute super amortisseur top coter puissance avec le pack 1100nimh ça pousse bien prochain test en lipo titi Share this post Link to post Share on other sites
Posted November 17, 2011 salut titi tu la essaye a vic? Je pense m en prendre un pour me faire un circuit privee a la maison il a l air d enfer je l ai vu en vrai sa a l air genial Share this post Link to post Share on other sites
Posted November 17, 2011 Le premier arrivage de mini 8ight est prévu fin du mois de novembre chez l'importateur français Share this post Link to post Share on other sites
Posted November 17, 2011 salut oui essayer a vic sur la piste rally est c est vraiment super ça marche fort on dirait un 10eme en plus petit c est qui l importateur en france? Share this post Link to post Share on other sites
Posted November 17, 2011 Je ne sais qui l'importe en france mais si il avait été en france en meme tps que l'angleterre ont aurai pu le commander ici, dommage voici les photos du mien Share this post Link to post Share on other sites
Posted November 17, 2011 MOI je l ai acheté en france. dit moi sur ton losi tu as mit quoi comme options tu peux me dire? merci Share this post Link to post Share on other sites
Posted November 17, 2011 Nous Non on avais besoin de 5 kits et on a pas trouvé ça en stock. la il y a juste supports amortos et platine carbone. j'atten les supports de triangle alu et ça suffira j'ai egalement mis un micro recepteur spektrum que j'avais dans un coin Share this post Link to post Share on other sites
Posted November 17, 2011 Les support de triangle alu tu les a trouver ou svp? si tu veux dit le moi en mp merci titi Share this post Link to post Share on other sites
Posted November 17, 2011 Les pces carbone sont les Losi ?? MP pour le "fournisseur". Merci. Stéphane. Share this post Link to post Share on other sites
Posted November 18, 2011 oui les pièces carbone sont des options losi Share this post Link to post Share on other sites
Posted November 18, 2011 les supports triangle alu pas encore dispo ni en EU ni aux US Share this post Link to post Share on other sites
Posted November 18, 2011 Bonne qualite Bon comportement, direction tres (trop ?) vive (en tout cas sur moquette avec pneus d'origine) Attention cependant : 2 chappes d'amortos petées en 2 packs sur 2 receptions de saut pourtant pas si moche que ça ! Qualité des plastiques ? Quoi qu'il en soit, je les ai remplacé par des chappes 1/10 (les boules d'origine rentrent pile poil dans celles de B4) La section de plastique entourant la boule etant plus consequente, il ne devrait plus y avoir de probleme de ce coté là Une bonne petite machine qui n'a rien à voir avec du 1/18 plus petit et surtout beaucoup trop leger (à mon gout) Share this post Link to post Share on other sites
Posted November 18, 2011 un vrai comportement de 4x4 1/10, tres directif et moteur d'origine deja tres puissant en lipo. bonne autonomie et tres bon comportement en l'air. sur moquette avec pneu d'origine trop d'accroche sur le toit a chaque virages, par contre passage sur roues DTM mousse 35 shore et la que du bonheur Share this post Link to post Share on other sites
Posted November 19, 2011 essai hier devant chez moi sur goudron avec un lipo 1800 25C a l acceleration il leve les roues avant ca marche grave Share this post Link to post Share on other sites
Posted November 20, 2011 ptite astuce, les ressorts arrieres étant un peux dur on peux les remplacer pas des ressorts avant de B4 Share this post Link to post Share on other sites
Posted November 20, 2011 Salut les chapes RPM pas nickel dessus car celle d origine sont un peut faible Share this post Link to post Share on other sites
Posted November 20, 2011 c'est bon a savoir je n'etais aps sur de la taille Share this post Link to post Share on other sites
Posted November 27, 2011 Bon et bien ce mini losi marche définitivement fort Astuces utiles: -rotules du bas des amortos plutôt fragiles, mettre celles du B4/T4 (boule interchangeable et plastique bien meilleur -ressorts avant du B4 pour les amortos arr du mini-8 -chappes RPM -roues mousse de dtm 1/10 en 35 shores sur piste indoor moquette encore quelques pack et nettoyage des diffs et test avec un huile de 5000 Share this post Link to post Share on other sites
Posted December 3, 2011 chappes RPM installées ainsi que les rotules amortos du B4 j'ai installé a l'arrieres les ressort avant Marron du B4, on vas voir mousse DTM 37 shores bientot les retours pour les interessés Share this post Link to post Share on other sites
Posted December 3, 2011 Salut moi j ai mi les ressort jaune yok a l arriere pas mal Share this post Link to post Share on other sites
