Posted July 25, 2015 1/10th scale oval and road racers... Time to put your rubbers on! Team CRC releases the new GTR wheel for CRC's new RT1 rubber tire. GTR wheel also fits TCS and Pit Shimizu tires! RT1 tires fit Formula 1 perfect, same mounting as Shimizu and TCS! 1/10th Oval, Legends and Road racers, think about this.... Running one season on the same set of tires.No truing, rounding and grinding, bolt on and race.Ride height staying the same for the season.No change in gearing because of tire wear.Fixed gear-ratio classes with no tire size issues.No chunked tires for the season.Awesome SCALE looks, appearance and performance. The new GTR wheels This is all possible with the new GTR wheels from CRC. These new wheels are designed for rubber tire 1/10th scale pan car racing, both oval and road. They are direct bolt on for 1/10th cars. In the rear, they use the standard 4 bolt mounting pattern commonly used in oval and World GT. In the front, they use the normal 1/8 x 5/16" bearing, again very common among the 1/10th oval and World GT cars. The mounted tires measure around 2.45" diameter, most all pan cars can be adjusted to make the proposed 5mm ride height rule. These rims are designed to mount the best performing tires on the market; the Pit Shimizu, Tamiya TCS and CRC RT1. The rims are designed for 2 types of scale looks; low profile (sidewall) GT type cars and large sidewall NASCAR and F1 scale looks. Standard offset makes it easy to mount and go! The new RT1 tire - For F1 and 1/10th scale These new tires are RACE PROVEN to provide great grip on carpet and asphalt. The tires have many months of testing and provide excellent grip and handling on both low-traction asphalt and high grip carpet. Under normal conditions, the tires show very little wear and no lap time degradation. The first run on these tires is no faster than the 30th run. The tires respond very well to all the popular additives. Dual scale looks - the tires can be mounted in both NASCAR/F1 style with a larger sidewall or GT style with low profile sidewalls. The tires come with inserts and measure 2.45" in diameter. Fit CRC GTR rims and Tamiya foam rims. Scale looks and performance - CRC GTR wheels + RT1 rubber tires CRC RT1 tires - Perfect combination for Formula 1 CRC RT1 tires mount in the same style as the most popular F1 tires; the Pit Shimizu (0571+0572) and Tamiya TCS. Our new RT1 tire performs brilliant with great grip and stability on carpet and asphalt. Coming soon from CRC; F1 rims and PRE-MOUNTED RT1 tires. GT style low profile or F1/ NASCAR large sidewall appearance. Available: 9-1-15 2310 GTR wheels for rubber tires-4 - Black 2311 RT1 Front rubber tires w/insert (pair) 2312 RT1 Rear rubber tires w/insert (pair) Available: Fall 2015 2314 Mounted RT1 Front tires on GTR 1/10th wheels 2316 Mounted RT1 Rear tires on GTR 1/10th wheels 2320 Mounted RT1 Front tires on F1 rims 2322 Mounted RT1 Rear tires on F1 rims www.teamcrc.com Share this post Link to post Share on other sites
Posted July 28, 2015 Voilà une bonne nouvelle... Les réticents aux mousses n'auront plus d'excuses pour rouler en PanCar !!! ;o) Share this post Link to post Share on other sites
Posted July 28, 2015 C'est vrai que ça a l'air pas mal, pour lancer une catégorie spec simplifiée (genre châssis VBC avec carro LMP1, vario/moteur 21.5t, 2S, pneus caoutchouc), c'est vraiment une super nouvelle! Bon après, en extérieur avec un gros moteur, faudra pas s'attendre à de grande chose, mais sait-on jamais ;-) Share this post Link to post Share on other sites
