Posted May 29, 2009 Avec le même problème que le X-6 première génération, un cascade trois pignon!!! Share this post Link to post Share on other sites
Posted May 29, 2009 et surtout un train avant de losi xxx-cr qui manque cruellement de directivité Share this post Link to post Share on other sites
Posted May 30, 2009 a voir rouler, avant de dire:youpi: Share this post Link to post Share on other sites
Posted May 30, 2009 Justement , je trouve que c'est un bon choix car le train AR motrice fort et avec le moteur central, cela redonnera du grip au train AV. Comme dis Jeam Marc, il faut essayer pour juger. Et une boite 3 c'est dramatique ? là c'est une version proto pour valider la conception, ensuite il leur reste à dessiner une boite 4 dans le style du S2. Share this post Link to post Share on other sites
Posted May 30, 2009 Avec le même problème que le X-6 première génération, un cascade trois pignon!!! c'est bien 3 pignons, mais le moteur est de l'autre coté la boite a été repercé pour faire passer l'axe du bon coté... Share this post Link to post Share on other sites
Posted June 8, 2009 Andy Griffiths was running the latest development from Atomic Carbon - the CR2. The car is based off the Losi XXXCR 2WD buggy but has a lot in common with a car seen a few years ago developed by a couple of the-Losi drivers. Whilst that car needed a lot of custom work to acheive a finished car - this Atomic Carbon car is designed to assemble with the minimum of fuss / hand finishing. The main chasssis is a flat plate of carbon fibre, with small carbon 'ribs' bolted down either side to give strength and stiffness. The front end uses the XXXNT nose piece to replicate the front of the XXXCR. Jonathan at Atomic Carbon is looking at possibly releasing this as a upgrade kit for the XXXCR, but not until it's been thoroughly tested and final design changes made. Oople Share this post Link to post Share on other sites
Posted June 8, 2009 c'est un kit de convesrion a partir d'un losi ou un kit complet? Share this post Link to post Share on other sites
Posted June 8, 2009 pour le moment c'est juste un proto Share this post Link to post Share on other sites
Posted June 9, 2009 je suis pressé de voir rouler cette caisse,magnifique ce qu a fait atomic carbon toujours a la recherche de la perfection:applo: Share this post Link to post Share on other sites
Posted June 9, 2009 Pour moi moins beau qu'un S2 Je le trouve beaucoup moins epuré Share this post Link to post Share on other sites
Posted June 15, 2009 il est quand même tres beau ^^ Share this post Link to post Share on other sites
Posted June 25, 2009 The Horizon sponsored guys at Eden Park all turned up with the new Atomic Carbon conversion for the Losi XXXCR - the fittingly named 'CR2'. The cars are final production spec apparently and differ from the car seen at the previous national round driven my Andy Griffiths. The cars use a standard Losi gearbox without modification - so the motor is running backwards, which is simple to acheive on most brushless controllers. Share this post Link to post Share on other sites
Posted June 25, 2009 magnifique , et puis super épais le carbone avec ses 3 epaisseurs sur le coté av .. Share this post Link to post Share on other sites
Posted June 26, 2009 il ont inversé le moteur :applo: Share this post Link to post Share on other sites
Posted June 26, 2009 Dégouté d'avoir revendu mon XXX-Cr... :k Share this post Link to post Share on other sites
Posted July 8, 2009 Cliquer pour agrandir / clic to enlarge Images: Wouter Share this post Link to post Share on other sites
Posted September 15, 2009 un petit blog anglais destiné au montage du cr2 I'm starting this blog to show you my cr2 build. Ill take photo's of each step of my conversion. I hope someone will find it useful. Gathering Electrics....... The Front End Share this post Link to post Share on other sites
Posted September 25, 2009 The built I received my cr on Friday and started the build..... I received my kit in a jiffy bag which inside had the chassis and parts all individually bagged. The only problem with the kit is the lack of instructions some bits might get confusing for some. BUT This blog will take you though a step by step guide to building... Share this post Link to post Share on other sites
Posted September 28, 2009 Tien le retour de l'hydra-drive losi (marrant comme idée). Share this post Link to post Share on other sites
